[ANSYS Meshing] What is the relationship between the "min size" and "proximity min size"
Old   January 24, 2016, 02:31
Default What is the relationship between the "min size" and "proximity min size"
wanghuo
hotboy is on a distinguished road
hello friends!
If I choose the "use advanced size function-proximity and curvature".There are "min size" and "proximity min size".What is the relationship between the "min size" and "proximity min size"?Thank you very much!
your sincerely hotboy!
hotboy is offline   Reply With Quote
Old   January 26, 2016, 16:14
Kapi is on a distinguished road
hotboy,
from help section in Ansys:
Proximity Min Size:
"When Use Advanced Size Function is set to On: Proximity and Curvature, Proximity Min Size allows you to specify a global minimum size to be used in proximity size function calculations, in addition to specification of a global Min Size. By default, Proximity Min Size is set equal to the default of Min Size. You can accept the default or specify a value greater than 0."
Go to help section in Ansys and search "Proximity Min Size" and "Proximity Size Function", it explains the relationship and what proximity is.
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
