[ANSYS Meshing] Inflation layer problems around engine
Old   April 26, 2016, 09:41
Default Inflation layer problems around engine
P.Adam
padam is on a distinguished road
Hi all!
I am modelling the flow around a wing equipped with winglet, and I have made the modell of the engine also. The problem is that when I put up the inflation layer, I would like to exclude the engine inlet and 2 engine outlets (from the fan and from the compressor flow), as they will be inner inlets and outlets of the whole flow regime.
The ideal mesh would look like as on the pictures of (inflation_3 and inflation_4), but without inflation layers on the inlet and outlets of the engine.
When I exclude those 3 faces from the inflation meshing, the inflation at the ends go further, than the face on which it is itself, and totally destroys the mesh of these faces, and the volume around them. (pictures inflation_1 and inflation_2).
Anyone got any suggestions as how to make the inflation layers stop at the end of the cylinder faces and not going further, and to normalise the engine inlet and outlet faces' mesh, as it is inteded to be.
Thank you very much, padam
padam is offline   Reply With Quote
[ANSYS Meshing] Inflation layer near gap with multizone mesh matmax-168 ANSYS Meshing & Geometry 0 April 24, 2015 09:32
[ANSYS Meshing] Inflation layer thickness based on y+ ziggo ANSYS Meshing & Geometry 1 July 29, 2013 15:17
Boundary Layer problems Petro ANSYS Meshing & Geometry 1 November 19, 2010 17:47
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
