[ANSYS Meshing] Creating local sizings within a body of influence. |
Euan
Rep Power: 6 ![]() |
I am modelling a tidal stream turbine.
I want to create both local sizings on the surface of the turbine blades as well as a body of influence generally around the turbine in order to resolve the wake and any other turbulent flows around the region of the turbine. I want the local sizing on the blades to have a smaller element size than in the body of influence as obviously creating a body of influence with too small a cell size will drastically increase the number of elements however I want a finer mesh actually on the blades. In the Ansys tutorials it states that local controls lower down in the tree will take precedence however when I try it the mesh on the blades is just the same as for the rest of the body of influence. Also I have checked the min cell size for the sizing on the blades is not incorrectly set too large. Thanks |
Euan
I believe I have solved this. The items lower down in the tree must have their behaviour set to hard, I previously had them set to soft.
body, influence, mesh, sizing |
Display Modes | |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
creating a solid body in Design Modeller | Dan | CFX | 0 | May 24, 2004 11:59 |
