[ANSYS Meshing] Ansys meshing problem
Old   May 5, 2016, 17:44
Default Ansys meshing problem
behzad Ghasemi
behzad-cfd is on a distinguished road
Hi dear forumers,
I want to mesh a cubic cavity with a thin region in it. I defined nodes and edges then parted the cub in 8 sections to define surface and perform a mapped mesh. I did not use sketch method because it's not produce desired mapped mesh around thin region. problem arises when i import mesh in fluent and it assumes that section lines are wall.
how can i solve this problem?
Geometry pictures are attached.
Thanks in advance
behzad-cfd is offline   Reply With Quote
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Mesh difference between 14.5 version and 15.0 version in ansys meshing sunxihui ANSYS Meshing & Geometry 0 May 6, 2014 04:22
[ANSYS Meshing] Problem with ANSYS Meshing - how to refine? pyroknife ANSYS Meshing & Geometry 2 August 22, 2013 13:30
[ANSYS Meshing] Meshing Problem in worbench elina ANSYS Meshing & Geometry 0 March 31, 2013 08:53
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
