[ANSYS Meshing] Geometry-Air Domain
Like Tree1Likes
  • 1 Post By Micael
Old   May 16, 2016, 18:56
Default Geometry-Air Domain
Chaitanya
cysanghavi is on a distinguished road
I have a complex geometry, where I want to simulate the air flow within the cooling channel of a drilling tool.
I want to simulate only the air flow within the cooling channel and not exterior to the cooling channel.
how to delete the air domain, which does not belong to the cooling channel ?
Does this make physical sense ? Since I am only interested in the temperrature profile of the tool at the outlet.
this is a CHT type CFD application.
Hope I make my point clear,
Thanks and Regards
Chaitanya
cysanghavi is offline   Reply With Quote
Old   May 17, 2016, 10:55
Micael
Micael is on a distinguished road
In either DesignModeler or ANSYS MESHING, can you pick the volume of the cooling channel? I mean, do you have a "body" that occupies only the cooling channel? If yes, you just have to "suppress" the other bodies and you will be left with only the body you are interrested to simulate.
Micael is offline   Reply With Quote
Old   May 17, 2016, 17:14
Chaitanya
Nope, unfortunately, I directly got the .stp file for my project and I do not have that stored as a body. In that case, suppressing was a real good way out.
I will try to look into the meshing module.
Old   May 17, 2016, 17:18
Micael
So, in Design Modeler you Create->Import External Geometry File... then pick your STP file, then press Generate?
Old   May 17, 2016, 17:25
Chaitanya
Yes. exactly.
Old   May 17, 2016, 17:33
Micael
how many body do you get then? Can you provide a printscreen of DesignModeler tree?
Old   May 17, 2016, 17:36
Chaitanya
I just get the .stp file on import.check the screen shot
Old   May 18, 2016, 03:10
Steffen595 is on a distinguished road
there is just 1 body then. Don't you have a CAD of sorts, where you can import it and then subtract it from a cylinder.
Or I guess in design modeller you can model a cylinder and then subtract thad body. I believe, there is somethong like that even in the mesher. There are a bunch of tutorials, multibody domain is the word(s). Shows how to make one solid inside the other one.
The most convenient way is use a CAD program.
Stuttgart, ey, Viertele-Schlotzer.
edit: there is a forum www.cad.de. I reckon, someone in there would extract what you want,if you are able to upload your stp file
Steffen595 is offline   Reply With Quote
Old   May 18, 2016, 16:57
Micael
Pick the 2 edges I highlighted in red then create surfaces:
Concept->Surfaces From Edges
then try to fill the cavity:
Tools->Fill, choose "By Cavity"
Hopefully this will work.
cysanghavi likes this.
Old   May 20, 2016, 10:12
Chaitanya
It did not work. But I used Solidworks and managed to use surface commands to fill up the material and Export it.
I could not get the exact Profile since the cooling channels had a complex geometry.
But the model works. But, it could not recognize the Interface in the CFX pre-processor. :P
Hope,it gives convergence. !
Old   May 20, 2016, 10:13
Chaitanya
Thanks for your Inputs and efforts. !!
Old   May 20, 2016, 18:43
would be just a sweep of a circle on a spiral?
Old   May 24, 2016, 09:39
Chaitanya
Nope, sweep does not work. I have the outlet a curved surface. So, sweep does not work.
I found out a way:
1. Solidworks. - Use offset surfaces, offset entities, fill the surfaces, use surface knit with high GT for Gap. and it works. !!
2. Rhyno can also be used. !
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Radiation interface hinca CFX 15 January 26, 2014 17:11
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Geometry basics. How do i model an open domain to simulate a jet flow canev.civelek ANSYS 7 March 12, 2012 05:26
interface domain: air and aluminium Rogerio Fernandes Brito CFX 1 July 31, 2008 07:08
