[ANSYS Meshing] body of influence vs. contact region
Like Tree1Likes
  • 1 Post By Diger
Old   July 14, 2016, 15:52
Default body of influence vs. contact region
Diger is on a distinguished road
I'm using body of influence for the meshing from one region to another, but everytime I set up the element size/body of influence setting the contact region between those two regions changes into a question mark...
Does anyone know which problem could arise here?
edit: maybe to clarify. As soon as I select the body of influence and hit select the contact regions of this body of influence become a question mark.
Diger is offline   Reply With Quote
Old   July 17, 2016, 22:32
Kapi is on a distinguished road
put some pics
delete all auto generated contacts and create contacts manually
Kapi is offline   Reply With Quote
Old   July 18, 2016, 04:38
Thx for ur reply. I sorted this problem...Sorry not to mention: The issue was that I didnt use multibody for my parts an thats why many contact regions arose. With multi-body in DM this issue does not arise. Though still now I have another problem instead. The body of influence chosen is not considered in the mesh. It's gone and I have a gap in my body :-/
U want some pics about it or is it clear enough?
Old   July 18, 2016, 18:36
pics are equivalent of 1000 words.
SO always post pics and describe the problem.
Old   October 9, 2018, 09:17
yanki cob
yanki is on a distinguished road
Did you solve this problem? Basically I want to use Body of Influence, but I also want to keep the "body". Is this even possible?
yanki is offline   Reply With Quote
Old   October 10, 2018, 07:41
Unfortunately not :-(
I guess I "solved" it by splitting my body into a couple of parts and choosing different element sizes for each of them.
But if you find a solution I'll be happy if you share it :-)
yanki likes this.
[ANSYS Meshing] Body of Influence and Method on same geometry possible?! pizzaspinate ANSYS Meshing & Geometry 0 January 4, 2016 10:45
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
how to contact multi fluid region in ansys DM oilsok ANSYS Meshing & Geometry 1 January 14, 2011 17:06
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
