[ANSYS Meshing] how to check y+ validation for Aerodynamics
Old   August 1, 2016, 06:38
Exclamation how to check y+ validation for Aerodynamics
sime
babri is on a distinguished road
hi
as you know Y+ value dependent on friction velocity , i want to test a vehicle aerodynamics and Gaining it's drag coefficient, also i read some articles in this website about Y+ but i don't realize Y+ significance for aerodynamic test , because on the different points of vehicle surface friction velocity is different with other points so Y+ value may change too much !
as i said now i have 2 problem ; 1-for aerodynamics analysis i should keep Y+ value in specified rang and if it is true what is this rang ?
2-when friction velocity is different is vehicle surface how i can keep Y+ value to gain a accurate drag coefficient ?
babri is offline   Reply With Quote
Validation for a channel flow code jinhua2015 Main CFD Forum 7 December 31, 2015 12:03
NACA0012 Validation Accuracy Improvement Alhasan OpenFOAM Running, Solving & CFD 8 February 1, 2015 08:39
Urgent: RAE 2822 validation NID Main CFD Forum 0 September 3, 2004 10:34
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
Fluxes validation Mavinakere FLUENT 0 May 22, 2002 23:24
