[ANSYS Meshing] How to get rid of skewed elements while meshing a pipe with many interfacing surfaces
Old   June 2, 2012, 12:18
Default How to get rid of skewed elements while meshing a pipe with many interfacing surfaces
everdimension is on a distinguished road
Hello!
Here is an object that i want to perform analysis on: http://dl.dropbox.com/u/55240438/ima...so_section.png
Here is the geometry i made in design modeler. I had to slice it many times to be able to create 'sweeped method' mesh at those sections. I also made round corners where the fluid makes sharp turns. Then i applied virtual topology onto those corners so that the inflation is not interrupted there.
For some reason i get smooth and even inflation when i use "total thickness" method. Here is what you get: pic1 and pic2
It looks like a good mesh, but it has some bad elements. After playing with the inflation layers number and total thickness size the mesh was improved. After that i tried to raise the "Relevance" value. For some reason its effect cannot be predicted. I got best results at the relevance "20", "21" and "23" and other values just worsened the mesh severely. Also the result on one and the same value is not always the same after regenerating the mesh a few times.
The best parameters i got were
Min Orthgonal Quality: 0,152
Max Skewness: 0.9251
After improving skewness i was able to finally reach convergence in FLUENT but only at k-e turbulence model.
So I wish to improve the mesh more and i need help and advice.
Please, help
You may download my project here http://dl.dropbox.com/u/55240438/ima...ipemeshing.rar
everdimension is offline   Reply With Quote
Old   June 4, 2012, 02:29
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
I had a quick look at your geometry, first do you have access to ICEM? If yes I should proceed with this meshing software as it allows you to create easily O-grids and permits more "control" than Ansys Meshing.
You can still create O-grid with AM, just split your inner pipe and assign mapped faces (I generate a coarse mesh just to show you the principle). You will have a far better mesh. I would also assign "sweep" methods to your parts, using source and target face in order to "help" the meshing software. I quickly split your geometry and created 2 O-grids. If you spend more time splitting your geometry you could improve your mesh metrics
Gweher is offline   Reply With Quote
Old   June 4, 2012, 04:51
Thank you for the reply!
Well, that looks very good, i didn't know about this method.
But how will the mesh behave at the 'branches' and at the 'turn' when the inflation is added? And as I understand you still cannot avoid tetra cells, and the parts where hexa cells transform to tetra are the most problematic ones.
And, hmm, how did you 'quickly' split the geometry like that? I can think of one way but it's really not quick...))
And I do not have ICEM, unfortunately.
Old   June 4, 2012, 20:17
Gweher's Avatar
Gwenael H.
Well for the splitting it took me 10-15min, but once you know how to do it it's quite easy and quick. You just need to split it like I showed it previously. I'm more familiar with ICEM but I use AM for simple geometries, and then use multizone to mesh more "complex" one with ICEM.
For the inflation layers I'm not sure how it will "behave" with AM, I should first assign sweep methods to your parts and then right click on that method and use "inflate this method". And as I said before, for me it's way easier to mesh your geometry with ICEM, but as you don't have it you should continue splitting your geometry into easier "meshable" sub-parts.
If I have some time, I'll try to find a way to mesh your geometry within AM.
Old   June 5, 2012, 15:41
Turns out i do have ICEM CFD! That was very pleasant to find out.
So i installed it, but obviously it is going to take some time learning how to use it. I really hope that in the end I would be able to mesh this model with high quality elements. I would be grateful for any kind of further tips.
Thank you, Gwenael, for looking into my model.
By the way, i was able to improve the mesh in Ansys Meshing even a little more just by adding same 'edge sizing' for all of the sweepable elements.The max skewness is now 0.899, min orthogonal quality is 0.159, but... The simple 'element quality' property is as low as 0.043. Do I understand correctly that this property is also important and it shouldn't be that low at all?
Old   October 2, 2014, 23:45
hwet is on a distinguished road
minimum orthogonal quality of as low as 0.1 is acceptable
hwet is offline   Reply With Quote
you can also improve your mesh further in fluent by just a few clicks
Old   September 13, 2016, 12:01
Default Meshing Complex Geometry
Ata
Ata.tavakkoli is on a distinguished road
Dear every body
i need help in meshing complex geometry
i have tried many options but still my calculation not converge
how i can send my geometry file to you ?
Ata.tavakkoli is offline   Reply With Quote
Old   September 13, 2016, 18:59
Kapi is on a distinguished road
post pic of your geometry and settings u r using!
Kapi is offline   Reply With Quote
Old   September 14, 2016, 03:28
Default Pic of Geometry
Ata
Dear Sir
please check picture i attached . the picture is taken from meching window , you can see setting which i made to . and skewness quality bars exist in bottom .
thanks
Old   September 15, 2016, 02:22
click on the bar to see which places have high skewness
then pick those faces/edges and give sizing on them. Make sure you use behavior as "Hard" in your sizing function
Old   September 15, 2016, 02:55
Ata
when i click on the skewness bars it does not show anything on geometry .
may i have to enable any option in setting ?
Old   September 15, 2016, 18:54
it should show, no settings for that
when you click on it, what does it show? can u take pic?
heat exchange, heat flux, hex, meshing, tetra
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
Meshing divergent nozzle entry of a long pipe Aly FLUENT 1 September 25, 2005 17:07
+ shape circular pipe - meshing possible? Selina Tracy Main CFD Forum 2 January 16, 2003 13:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
