[ANSYS Meshing] Can anyone tell me how to mesh such complex model in Ansys..?? |
December 22, 2016, 04:01 |
Adi
Rep Power: 9 |
I have tried a lot and am not able to mesh it for fluent analysis and its urgent.Please tell me whether I even have to mesh it or not for fluent analysis.
December 22, 2016, 04:30 |
Onur Özcan
Rep Power: 12 |
first, cut/slice from axis of domain
December 22, 2016, 06:05 |
Adi
Rep Power: 9 |
How would this help. Actually when I click generate mesh errors like duplicate surfaces etc are show and I think it is due to the complex assembly can you help me out plus can u tell me in what format would it be best to transfer assembly from solidworks to ansys
December 22, 2016, 08:35 |
#4 | |
Onur Özcan
Rep Power: 12 |
December 22, 2016, 08:37 |
Onur Özcan
Rep Power: 12 |
December 22, 2016, 23:28 |
Adi
Rep Power: 9 |
Geometry transfer is OK but meshing is not being done. I even tried slice from the axis of domain but still I am not able to do the meshing. Every-time its showing error. The Model is too complex. Can you show me how to do the meshing....!!If you want I can send you the model on your mail id.
December 23, 2016, 00:07 |
Rep Power: 18 |
First of all defeature your geometry by removing all unnecessary details.
December 23, 2016, 00:47 |
david
Rep Power: 13 |
In ANSYS ICEM, build topology first. Then under the blocking tab, select 2D surface blocking. Use mostly mapped and select all tri. Then you can specify which areas you want your mesh to be dense. All this under blocking of course. Once you're happy with the surface mesh, right click pre-mesh and convert to unstructured mesh. This will give you a surface mesh. After that, use the Delaunay mesher with existing mesh option.
Sent from my iPhone using CFD Online Forum mobile app |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[ANSYS Meshing] ANSYS mesh - I was surprised... | assafwei | ANSYS Meshing & Geometry | 0 | September 4, 2014 12:17 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
