[ANSYS Meshing] Windows - Interface or Interior |
February 4, 2017, 09:58 |
Dionysis
Rep Power: 9 |
Hello everybody,
I'm trying to simulate the airflow in and around a greenhouse for my thesis. My problem is how to approach the windows. I have 3 different window opening positions. I created 3 separate solids, with the intention, in fluent, to be able to define which is a wall (the one I want to simulate) and which an interior (the other two). When I go to Meshing it recognises a contact region between the two windows and afterwards in fluent I can't define them as an interior, so they will not interfere with the solution. I also tried to merge the 2 faces between the windows but again no luck because the minimum angle isn't between 90-180. Thanks in advance. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Access value in cell across an interior interface | iteration | Fluent UDF and Scheme Programming | 1 | July 13, 2016 04:38 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
How to define the heat flux in the interior interface between two phases | fangdian | FLUENT | 1 | November 18, 2013 07:23 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
