[ANSYS Meshing] Symmetry feature in ANSYS Meshing |
February 22, 2017, 11:03 |
Roberto
Rep Power: 11 |
Hello everyone.
I'm running simulations in CFX with a very large geometry, which ends up having very large numbers of elements in the mesh as well. In answer to this problem (it is a problem because of data storage capacity and computational capacity as well) I chose to cut the geometry in half, after studying if this geometric symmetry would also correspond to the flow conditions, i.e. symmetry in the flow can be assumed to exist when observed from the same plane as where the geometric symmetry exists. The question is, as follows: In ANSYS Meshing, there is a feature that says "symmetry". I've been only using half of my geometry to cut down to half the number of elements and I've been also assuming that these conditions are the same in the other half, which is not represented. What is this symmetry feature for? Even if I'm using half of my geometry and generating the mesh on this half, do I have to use this feature for anything? Just wanted to know to prevent me from committing errors that may unvalidate my simulations. Thanks in advance for any of your helpful replies!!!! |
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD | Ctunramran | ANSYS Meshing & Geometry | 1 | February 23, 2016 07:06 |
Ansys airfoil meshing problem | Salah87 | ANSYS | 0 | August 13, 2015 02:49 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ICEM] 2d Aerofoil meshing in ansys ICEM | syler3321 | ANSYS Meshing & Geometry | 2 | February 3, 2012 01:59 |
[Other] Ansys meshing airfoil and / or compressor blades | baw192 | ANSYS Meshing & Geometry | 8 | September 23, 2011 00:43 |
