May 14, 2017, 07:09 |
Anchoring solid to another solid
Shlomi Bouscher
Hi all
I've been facing some trouble with the following situation: Suppose I have a "r" shaped geometry where each of the straight segments has some parametric length. I want to change the vertical segment's length while still having the horizontal segment at the top of it, meaning that I need to somehow anchor the horizontal segment to the vertical segment. Is there an easy way of doing this? I've looked at other forum threads and the ansys manual but didn't find anything. Thanks in advance! Shlomi |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid | amrbekhit | CFX | 0 | January 8, 2015 16:39 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
