[ANSYS Meshing] Pointwise Mesh to Fluent
Old   September 4, 2017, 11:44
Default Pointwise Mesh to Fluent
Jepp
Jepp is on a distinguished road
Good pm to all, I would like to seek your help for the following:
I finished the meshing at Pointwise and imported the mesh to Fluent.
The shape of the imported mesh in the fluent is not what intended to do. The airfoil is missing. Can you please help me? Here are the photos
Jepp is offline   Reply With Quote
Old   September 6, 2017, 03:42
Far
Sijal
First thing this is neither Pointwise forum and nor fluent forum. On point wise forum there are very good people and they are expert in it.
Now to the point, make four files. Three files for three airfoils and fourth file for the outer domain. mesh them and export them. Import them in fluent. For first file (any one) use file > read. For next three files use append command. And then use interface panel to create interface for three airfoils with the outer domain.
Old   September 6, 2017, 22:52
Default ANSYS Meshing and geometry
Jepp
Dear Mr Far,
For the forum, this is noted. I am just new here.
Anyway, what I've done is that I have 7 domains. What I've done is to select all these domains, select "Edit" and "Join". Then the 7 domains became only one done. Is it equivalent? Attached here are the screenshot.
Thank you very much in advance!
File Type: jpg 7 domains joined and became 1 domain.jpg (124.0 KB, 11 views)
Old   September 10, 2017, 00:24
Far
Sijal
No. In this way you cannot get relative motion in Fluent. Use them separately.
Use append command in fluent to join them. Finally use interface to connect them mathematically. See image for append command.
Exporting Mesh from Pointwise to ANSYS FLUENT mrswordf1sh Pointwise & Gridgen 14 September 6, 2017 10:23
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 16:52
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 09:43
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 02:22
