September 4, 2017, 11:44 |
Pointwise Mesh to Fluent
Jepp
Rep Power: 8 |
Good pm to all, I would like to seek your help for the following:
I finished the meshing at Pointwise and imported the mesh to Fluent. The shape of the imported mesh in the fluent is not what intended to do. The airfoil is missing. Can you please help me? Here are the photos |
September 6, 2017, 03:42 |
First thing this is neither Pointwise forum and nor fluent forum. On point wise forum there are very good people and they are expert in it.
Now to the point, make four files. Three files for three airfoils and fourth file for the outer domain. mesh them and export them. Import them in fluent. For first file (any one) use file > read. For next three files use append command. And then use interface panel to create interface for three airfoils with the outer domain. |
September 6, 2017, 22:52 |
ANSYS Meshing and geometry
Jepp
Rep Power: 8 |
Dear Mr Far,
For the forum, this is noted. I am just new here. Anyway, what I've done is that I have 7 domains. What I've done is to select all these domains, select "Edit" and "Join". Then the 7 domains became only one done. Is it equivalent? Attached here are the screenshot. Thank you very much in advance! |
September 10, 2017, 00:24 |
No. In this way you cannot get relative motion in Fluent. Use them separately.
Use append command in fluent to join them. Finally use interface to connect them mathematically. See image for append command. |
Exporting Mesh from Pointwise to ANSYS FLUENT | mrswordf1sh | Pointwise & Gridgen | 14 | September 6, 2017 10:23 |
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) | Joachim | ANSYS | 3 | April 24, 2016 16:52 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 02:22 |
