[ICEM] Assigning different number of nodes to parallel edges
Like Tree1Likes
  • 1 Post By Rohit
Old   July 22, 2012, 11:37
Default Assigning different number of nodes to parallel edges
Rohit Bhaya
Rohit is on a distinguished road
Hello everyone,
I have developed a geometry in ICEM CFD, whose blocking structure is defined in the pic below.
I have been trying to assign different nodes to the edges A & B (in the fig), but wasn't successful in doing so. On assign the nodes to one of the edge(blocking --> Pre mesh params --> edge params), it gets updated to the other parallel edges. I have tried -
1.) specifying the number of nodes to each and every edge
2.) converting the nature of blocks to free/swept instead of mapped
but the result would be same.
I require that the edges A & C(in the fig) should have the same number of nodes, which would be different from B & D. Can anyone, please guide me on how to pursue with this problem.
Thanks
Rohit
kmou likes this.
Last edited by Rohit; July 22, 2012 at 11:41. Reason: figure not uploaded properly
Rohit is offline   Reply With Quote
Old   July 22, 2012, 15:45
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
This is impossible if you want to create a hexahedral mesh.
Opposing edges of a block must have the same number of nodes.
flotus1 is offline   Reply With Quote
Old   September 23, 2015, 20:35
Cristian Osorio
c.osorio.r is on a distinguished road
Hi, flotus1, related to the same question, can be parallel edges in different blocks, dissociated?
c.osorio.r is offline   Reply With Quote
Old   September 22, 2017, 09:16
Camille Bilger
kmou is on a distinguished road
HI Flotus1,
I have the same problem but my edges are parallel but not of the same length... so obviously I have calculated on paper the number of nodes each edge would need to have to avoid hanging nodes... but I cannot set those numbers, since ICEM changes them, hence creating hanging nodes.
kmou is offline   Reply With Quote
icem cfd 13.0
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Dissociate blocks number of nodes gi12 ANSYS Meshing & Geometry 2 February 23, 2012 22:33
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 17:16
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 20:46
