October 5, 2017, 19:36 |
BladeGen Import Data Wizard
Québec
I would have some questions about the Import Data Wizard of BladeGen : I have a text file with my blade coordinates and another text file with my casing coordinates. When I go to the Import Wizard and insert my 2 files it works well but then it asks me 3 things: select the hub curve(s), the shroud curve(s) and the blade objects. Tell me if i'm wrong but I guess that the shroud curve is my casing geometry and the blade object the blade geometry, but how do I select the hub geometry ? Thanks a lot |
How to import a data file (excel,txt or csv)to Fluent or CFD-Post? | silvai | ANSYS | 16 | January 31, 2020 04:52 |
[Other] BladeGen Data Import Wizard | kariz | ANSYS Meshing & Geometry | 9 | August 28, 2018 15:07 |
How to import a data file (excel,txt or csv)to Fluent or CFD-Post (the easiest one)? | silvai | FLUENT | 0 | January 5, 2015 09:22 |
I-DEAS CAD data import with boundary conditions | Yunus | Siemens | 1 | June 1, 2001 10:04 |
