[ICEM] Parametric Model with Design Modeler and ICEM
Prev Previous Post   Next Post Next
Old   October 10, 2017, 05:45
Default Parametric Model with Design Modeler and ICEM
mss7979 is on a distinguished road
Hi everyone,
I've been silently reading on this forum for a while now and I have to thank you for all your support so far. Now I myself have a problem, for that I can't seem to find the solution:
I am modelling a axisymmetric flow through a cavity between a rotor and a stator. The geometry is fairly simple and completely symmetric. Therefore I modeled the cavity in the Design Modeler and defined parameters for the Geometry (e.g. Diameter, width, Extrusion angle etc.) and meshed it in ICEM.
When I only do small changes to certain parameters, my model seems to work just fine. The association of the blocking in ICEM works perfectly.
But if I change a parameter drastically, the diameter for example, ICEM seems to confuse the association of the geometry. This results in a completely unusable mesh. As I Previously mentioned, my geometry is simple and nothings changes but the dimensions of the Geometry itself, so the total amount of vertices,edges etc. stays the same.
So my question ist: What do I have to do to make my model truly parametric, even with big parameter changes?
Kind regards,
Maurice
mss7979 is offline   Reply With Quote
[ICEM] Model size inconsistency between DesignModeler and Icem Kristin_N ANSYS Meshing & Geometry 0 April 12, 2012 08:55
[ICEM] Gambit to ICEM, any advices ? Santos-Dumont ANSYS Meshing & Geometry 15 February 28, 2012 19:07
[ICEM] Design modeler to ICEM jsm ANSYS Meshing & Geometry 6 June 14, 2010 22:03
IGES Solid Model for ICEM Tet Mesh Samer Main CFD Forum 1 September 17, 2008 12:33
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
