[ICEM] Mesh refinement in a cylindrical geometry
Old   January 15, 2018, 08:39
Default Mesh refinement in a cylindrical geometry
Somashekhar Kulkarni
somas123 is on a distinguished road
I'm trying to refine the mesh inside a cylinder like geometry. The 3D blocking was produced by converting the mapped 2D surface blocking using the multizone method. I've tried using a density box spanning from the inlet to some height above the inlet but in vain. How do I go about it?
somas123 is offline   Reply With Quote
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 19:34
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies MBttR OpenFOAM Meshing & Mesh Conversion 7 October 14, 2016 03:57
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
