[Other] Connecting 3D bodies in Ansys Design Modeler
Like Tree2Likes
  • 2 Post By PSYMN
Old   June 7, 2010, 18:50
Post Connecting 3D bodies in Ansys Design Modeler
chipper is on a distinguished road
Hello all,
I try to design a catalytic converter in 3D with ansys 12.1 design modeler. I connect different parts of the converter(i.e. inlet pipe, connecting cone, monolithic chamber, etc) with "skin/loft" feature. The problem is that when I try to use the model in Fluent, it recognize the connecting parts between different parts as "wall" while all of them are just "interior". I tried to use "Named Selection" feature in both Design Modeler and Meshing tools to define these connecting parts as just interior but I could not succeed. Also, I defined all the three parts I have in my model as Fluids in design modeler but still when I use meshing tool , it recognize the connecting sketches as "bonded-solid to solid" , which I could not change, and so treat them as wall. I will appreciate it if someone has a solution for it.
Best regards
chipper is offline   Reply With Quote
Old   June 18, 2010, 14:10
Default MultiBody
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You probably need to join the parts together as a multibody part in DM...
Right now it sees them as several parts that are touching, it will mesh each separately, etc. Once they are a multibody part, it will mesh it all at once.
Simon
PSYMN is offline   Reply With Quote
Old   June 18, 2010, 21:42
Thank you so much Simon for your reply.
The problem is that I need to have different parts in my scheme, because for example one part is porous and in one of them I have reaction. So, I had to freeze each part in DM to have them on Fluent for further work. Do you know a way that I could have different parts in DM and meanwhile it just recognize them as a continuum media?
Sincerely,
Chipper
Simon
Old   June 19, 2010, 09:46
Default Named Selections
PSYMN's Avatar
Simon Pereira
Sure, go ahead and make the multibody part so that it will all be meshed conformal... Then (before or after meshing) right click on each body and create a named selection (similar to how you lable inlets and outlets, but make sure that the selection is for bodies not faces). These named selections tag each volume for Fluent bocos (just as they tagged faces). So you could name one porous, another Fluid1, another Fluid2, another solid or whatever...
Nurzhan and Khan_CFD like this.
Old   January 25, 2018, 09:45
et.one is on a distinguished road
I would like to create different parts ( different connected volume) but all being part of one body. I have not found anything on the forum.
Please Can anyone help me or tell me where I can find the answer?
thank you very much in advance
et.one is offline   Reply With Quote
ansys 12.1, ansys design modler, catalytic converter, connect bodies, interior boundary
2-D Design Modeler Geometry - Ansys 12.0 hodeje01 ANSYS Meshing & Geometry 2 October 7, 2009 10:42
Any other way of converting a multi part to a single part avoiding ANSYS Design Model LusoMundo ANSYS Meshing & Geometry 1 May 14, 2009 14:35
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
CFX design modeler Merkur CFX 0 June 5, 2006 10:44
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
