[ICEM] Extrude 2D block for 2D simulation in ICEM |
February 27, 2018, 09:54 |
sunil
Rep Power: 13 |
Hello everyone,
I ant to simulate 2D case in Fluent. I am generating 2D structured mesh in ICEM, I am trying to extrude 2D block along the curve same as we do with 3D blocks. I am unable to extrude 2D block (Refer the image) is there any alternate way to fit block there. please help me to resolve the issue. |
March 1, 2018, 10:16 |
sunil
Rep Power: 13 |
Hi Far, Thank you for your reply. I am not creating any 3D block. I am interested in generating 2D block only.
As you suggested I tried with block from vertices but it requires at least 3 vertices to create block and that is not worked, any other suggesting?? |
March 4, 2018, 22:19 |
sunil
Rep Power: 13 |
Hi Far, Thanks again for your reply.
I tried as you suggested but I am unable to select the points for creating block. I have used the following method to overcome the issue 1. Generated the required block separately and loaded in existing project 2. under Blocking->Topology we will get one more block list 3. merged both existing and imported block after proper association I am able to generate mesh for my outlet section now. Thank you |
2d block, extrude |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[urgent] ICEM: from 2D to 3D using extrude | Hao | CFX | 3 | March 11, 2010 12:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
block strategy in ICEM | Li | CFX | 1 | October 16, 2008 04:20 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
