[ICEM] Rotational periodic problem
Like Tree1Likes
  • 1 Post By m5edr
Old   March 18, 2012, 11:31
Default Rotational periodic problem
mohamed khedr emam
m5edr is on a distinguished road
Iam try to make a two face periodic boundary
Mesh --> Global Mesh Setup- Global Mesh Parameters - Setup periodicity -Rotational Periodicity
Base : "I selected first point in my geometry"
Axis: 0 1 0 ( rotated about y-axis)
Angle: 120 ( sector makes 120 degrees)
volume mesh is tetra/mixed , octree (NO Blocking is used)
shell mesh is All Tri , patch indep.
Icem tell me "Finished compute mesh" But
1- view of two face is STRANGE ,
2- and massage appears during mesh computation such (can't fix spike point on periodic boundary) and (periodic triangle matches tet but no tri)
My mesh is o.k or Not ?
any suggestion
m5edr is offline   Reply With Quote
Old   March 18, 2012, 22:01
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Have you checked the mesh for periodic problem?
rikio is offline   Reply With Quote
Old   March 18, 2012, 22:11
mohamed khedr emam
thanks for reply
No ,how i do this check?
Old   March 18, 2012, 22:23
Rikio
Edit Mesh —> Check Mesh
Old   March 20, 2012, 08:50
mohamed khedr emam
I did the periodic check , ICEM created a subset contains 200 error due to Periodic problem (it asked me the faces that contains periodic)
the stranger thing , if i send the mesh to fluent >>> No problem appear in periodic faces and seems good (if i do a check in fluent it massaged a problem)
i attached two image of the periodic subset and two periodic faces
Important Notes:
1-A massage appear "shell () has node () which has no twin"
2-Each Face of periodic contains two face where one BIG face and SMALL face "small face inside the BIG" .. and a straight curves between them
Volume mesh is Octree , shell mesh is ALL TRI/Patch indep.
Any suggestion (do i neglect the error?)
thanks
baqireng likes this.
Old   April 14, 2016, 22:16
Shahzada
zeeshu is on a distinguished road
so have you solved your error i have the same problem
zeeshu is offline   Reply With Quote
Old   May 2, 2018, 03:00
Default quality improvement
Saad
saad53 is on a distinguished road
Hi!
I'm trying to mesh my aircraft geometry for my project in icem. but the mesh contains spikes and penetrating elements due to which the mesh is of unacceptable quality. i have attached a few pictures of the mesh. some guidance would be really appreciated. the mesh is generated by octree method with prism layers on the wing.
saad53 is offline   Reply With Quote
Old   May 2, 2018, 03:40
Gert-Jan
Gert-Jan will become famous soon enough
It looks like some curves are missing.
After a tet-mesh is created, ICEM projects the nodes of the elements on the geometry. Here ICEM obeys some kind of hierarchy. If present, ICEM projects elements to points. Then to curves. And if none are present, then to surfaces.
In your case (and espcially in figure 4) there is no curve at the end of the surface. Then ICEM projects the nodes to a surface, making the edge of your mesh look spiky.
So you have to make sure that curves are present at the edges of all surfaces.
Good Luck, Gert-Jan
Gert-Jan is online now   Reply With Quote
Old   May 5, 2018, 10:38
Saad
Thanks for replying Gert-Jan
i have attached the geometry pictures, i am not an expert at it so the curves look fine to me somehow, if you could kindly take a look and tell me if it is the problem i'm facing. would be kind of you to take a look
please ignore the green curve in the tail as i used it to segment the surface in order to make the elements smaller at that specific area for the spikes to be fixed,but the problem still remains.
Old   May 6, 2018, 05:54
Gert-Jan
It is difficult to say, but my first impression is that you indeed have curves at the end of the surfaces. But curves are missing where surfaces are intersecting.
in other words, to me it looks like you have the surfaces of the plane body and surface of the wing. These surfaces of the wing are going through the surfaces of the plane body. Where these surfaces intersect, there are no curves.
What you should do is go to Create Curve>Surface Surface Intersections (5th icon). And create curves where surfaces intersect each other. You could opt to tick "Only Different Parts"
Periodic Pipe Flow LES dvolkind CFX 8 March 21, 2020 05:30
[ICEM] Specifying Periodic Vertices Causes Strange Problem Josh ANSYS Meshing & Geometry 5 July 19, 2011 16:09
Problem making a periodic boundary in helical coil Mikael FLUENT 0 January 24, 2008 10:22
Rotational movement in 2D problem Leverkin FLUENT 5 October 26, 2007 08:16
Periodic Boundary Condition problem, help arhgang FLUENT 7 October 31, 2001 07:22
