[TurboGrid] I wanna control this territory
Old   April 27, 2018, 02:22
Default I wanna control this territory
seunghyeon, yun
YOUNS is on a distinguished road
You can see large difference through circumference wise.
I want to decrease mesh size of this part.
tell me your tip~
Have a nice day!!
YOUNS is offline   Reply With Quote
Old   April 30, 2018, 03:23
M
AtoHM is on a distinguished road
1) Hide "show mesh" item
2) Choose a Layer and enable at least "Master Topology Visibility"
-> you should see purple lines at the layer
3) Hit right-mouse button on a line close to where you want to change the mesh size
4) Use "Edge Split Control" and assign a factor by which you want to increase the number of cells (can be decrease as well)
AtoHM is offline   Reply With Quote
Old   May 2, 2018, 20:09
Default I have a question.
seunghyeon, yun
Thanks your reply.
I have a question one more.
I use ATM.
Where is "Master Topology Visibility" ?
To my knowledge, this is manual mode and ATM is strongest mode in TurboGrid. right?
Have a nice day!!
Old   May 3, 2018, 05:58
M
I tested it and it works just as I described.
Master Topology can be enabled in the respective Layer properties. Double click a layer and it should be in the window opening to the left.
ATM is not "the strongest" mode, its just one of two options. It also has disadvantages, but in general gives high quality mesh.
The purple lines in the image are the master topology lines. Right mouse click on them allows you to add a edge split control item to any line.
Old   May 4, 2018, 03:53
Default Thank you!!
seunghyeon, yun
Thank you very much!! I found it!!
But, It's not easy~ I'll try to get mesh of good quality.
Thanks again.
Have a nice day!!
Old   May 4, 2018, 05:09
M
I think its pretty easy ... however, glad I could help.
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Problem with an old Simulation FrankW CFX 3 February 8, 2016 04:28
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 05:57
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 15:34
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 08:53
