[DesignModeler] Design Modeler scripting
Old   May 2, 2018, 07:34
Default Design Modeler scripting
winchler is on a distinguished road
Hi all,
I need to automatically create a set of spheres, depending on a list of point coming from an external file. I tried using a .js macro and until now I produce the following:
//Import the points
var fp1 = agb.FPoint(agc.FPointConstruction, agc.FPointCoordinateFile);
fp1.Name = "coordinatePoints";
fp1.CoordinateFile = "PATH\\file.txt";
agb.Regen();
//Generate spheres according to the sets of points from fp1 above
var i = 1;
while (fp1.GetPoint(i, 1)) {
    var SP = ag.gui.CreatePrimitive(1);
	SP.SphereRadius = "1";
	i = i + 1;
agb.Regen();
Points are correctly imported, but I am not able to do the following things:
  • Import points in a different unit systems
  • Create a sphere for each point (for the moment only one is generated)
  • Modify the center of the sphere using the previously read points
Can please someone help me or tell me where can I find a list of example and tutorials?
Thank you
Lorenzo
winchler is offline   Reply With Quote
Old   May 2, 2018, 09:53
Default Solved
Sorry, I just solved it:
//Import the points
fp1.CoordinateFile = "PATH\\FILE.txt";
agb.Regen();
var i = 1;
while (fp1.GetPoint(1, i)) {
    SP.SphereRadius = "0.00125";
    ag.listview.ActivateItem("Sphere");
    ag.listview.ItemValue = "SPHERE_" + i;
    ag.listview.ActivateItem("Operation");
    ag.listview.ItemValue = "Add Frozen";
    ag.listview.ActivateItem("Origin Definition");
    ag.listview.ItemValue = "Coordinates";
    ag.listview.ActivateItem("FD3, Origin X Coordinate");
    ag.listview.ItemValue = agb.GetPointX(fp1.GetPoint(1, i));
    ag.listview.ActivateItem("FD4, Origin Y Coordinate");
    ag.listview.ItemValue = agb.GetPointY(fp1.GetPoint(1, i));
    ag.listview.ActivateItem("FD5, Origin Z Coordinate");
    ag.listview.ItemValue = agb.GetPointZ(fp1.GetPoint(1, i));
    agb.Regen();
    i = i + 1;
Old   May 19, 2018, 06:21
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi Lorenzo,
I'm dealing with the same problem, gotta generate a plate with random holes in it and mesh it, all automaticaly using script,
would you mind sharing your text file containing the points you used in your script? I wanna generate the points using a code, but not sure yet how I should arrange them inside the text file
amin.z is offline   Reply With Quote
Old   May 21, 2018, 05:01
Hi, you can refer to this topic for the format!
Importing Points in Design Modeler
Old   May 22, 2018, 04:33
amin.z's Avatar
Amin
got it, thanks
design modeler, javascript, scripting
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
parametric study with design modeler and icepak aminem ANSYS 3 May 21, 2014 05:11
Scripting API Design Modeler - Spline mieszko1st ANSYS Meshing & Geometry 3 March 3, 2014 05:09
Design Modeler not working tan v ANSYS 0 July 7, 2011 02:43
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
