[ANSYS Meshing] Ansys always stuck when meshing my model. Please help.
Old   May 19, 2018, 07:16
Default Ansys always stuck when meshing my model. Please help.
Hao Wu
rokugo0512 is on a distinguished road
Hello everyone.
I am trying to test the mechanical properties of a closed-foam porous solid.
I have created a 10x10x10 hollowed tetrakaidecahedron stack. The thickness of each tetrakaidecahedron shell is only 0.25mm (as provided in attachment).
When I try to mesh this model using Ansys workbench's automatic mesh settings, I always stuck at the progress when it shows "Meshing volumes...".
I waited once for at least 48 hours but it just won't go through. But if the shell thickness is 1mm, the meshing volume process will finish in around 15 min.
Is there anyway to solve this problem?
rokugo0512 is offline   Reply With Quote
Old   May 20, 2018, 06:22
amin.z's Avatar
Amin
amin.z is on a distinguished road
Originally Posted by rokugo0512 View Post
Hello everyone.
I guess you’re encountering this problem deu to size of your elements, specially cause you’re using automatic mesh, ansys probably trying to generate a relatively fine elemnts in your domain, and since your part is too thin, the elements have to be too fine as well,
I can now think of two ways,
First , if possibel, would suggest to model a smaller part of your domain, considering a periodic or symmetry boundary conditions, the smaller you bring in meshing, the better you can estimate and solve your problem, e.g. bring a 1/8 of your whole domain, mesh it with the same method you were using earlier, now i guess the mesh would be generated, check the size and number of elements, I guess it’s probably too fine which causing a problem when you’re trying to mesh the whole domain. Does your computer have enough resource to generate the same quality for the whole domain which has for instance 8 times more cells?
Second idea is forgetting using the default value and auto mesh, go ahead and either give an elemnt size to your domain, or use a coarser size in default values of auto mesh, which probably gonna fail if you have a complex domain with curvature and narrow gaps
amin.z is offline   Reply With Quote
Old   May 22, 2018, 10:20
Hao Wu
Thanks a million!!!
I will try it right away.
[ANSYS Meshing] Meshing in Ansys for 3D model neda.m ANSYS Meshing & Geometry 1 September 11, 2015 13:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 09:48
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
