[ICEM] How to merge meshed parts?
Like Tree2Likes
  • 2 Post By Ludvik
Old   May 20, 2018, 12:00
Post How to merge meshed parts?
Julian121 is on a distinguished road
I am trying to merge two meshed parts, upstream part of rotor and the rotor itself.
The reason why I divided the rotor domain into two parts is because a type of vane-recessed casing treatment is placed on the top and upstream of the rotor.
The lower part of casing treatment is one millimetre shorter than the shroud so the casing treatment domain must go inside the rotor domain.
I used bladegen to create the rotor domain and used Solidworks to create the upstream domain.
When I import both meshes they are not placed near each other in ICEM even though I used correct dimensions.
I do not need an interface between them too.
Any suggestion would be welcome!
Julian121 is offline   Reply With Quote
Old   May 20, 2018, 14:32
Far
Sijal
Do you have blocking for both?
Old   May 21, 2018, 03:52
Post
No, I used Turbogrid to generate mesh for the rotor and exported it to ICEM.
For the upstream part of the rotor I used ANSYS meshing.
Can these two meshes be merged in some way in ICEM without a need to use blocking?
Is there any alternative way of creating the upstream part and the rotor in one step? Bladegen does change the shroud curve even piecewise linear is selected for the shroud curve.
Old   May 21, 2018, 10:45
Far
Sijal
You can merge them.
Old   May 24, 2018, 04:04
Jan Surwiło
johny0688 is on a distinguished road
I can hardly believe that, but anyway.
Turbogrid stick only to radial and axial dimension so the circumferential position of inlet and outlet is random. I think that the best method is to check coordinates of corner nodes at inlet to rotor domain and based on that create your upstream part in Solidworks. Then generate upstream mesh in Mesher.
But still it is very hard to merge two meshes in 1:1 because you need the same spacing on both surfaces. Why you don't want interface? For me it won't influence significantly.
johny0688 is offline   Reply With Quote
Old   May 26, 2018, 09:08
Post
Is there an easier way to draw the rotor and the upstream of the rotor (the upstream part is shorter because of the casing treatment) in one geometry instead of separating them?
I tried to do so in bladegen, but as I said when the geometry is imported in Turbogrid or ICEM, the right corner angle changes.
Old   May 28, 2018, 02:49
Ludvik is on a distinguished road
An another possible way:
1. Create a mesh in TG just for rotor itself.
2. Create a geometry for upstream part.
3. Load mesh from TG into ICEM CFD and extract mesh on a interface.
4. Create a block(s) for extention.
5. Convert the block(s) to Sweept with main Source Face on the interface.
6. Use command Associate Face-> Surface/Reference mesh.
7. Create Premesh/Mesh. Merge both parts. ...
Julian121 and aero_head like this.
Ludvik is offline   Reply With Quote
Old   June 2, 2018, 02:36
Thank you for the answer.
I have followed your instructions but when I convert the block into sweept with main source face on the interface, the face cannot be selected to associate with rotor mesh. Please see the screenshot.
Old   June 2, 2018, 13:00
Far
Sijal
Use ICEM CFD for this purpose. Or create interface but that should be upstream or downstream of casing recess.
Old   June 3, 2018, 01:52
Dear Far
Since the height of the upstream domain is shorter than the height of the rotor, the interface between the two domains should be applied based on the upstream height right? If so, how the inlet face of the rotor should be divided? I have not used blocking in ICEM so I cannot create two parts based on the blocking. I have imported the mesh from TG.
Old   June 3, 2018, 05:29
Far
Sijal
see this reference...
https://www.researchgate.net/publica...ed_Endwall_NGV
[mesh manipulation] Best way to merge meshes? Tensian OpenFOAM Meshing & Mesh Conversion 0 November 27, 2016 07:07
Generate Parts Using Named Selection jonasohlsson ANSYS 1 March 14, 2016 04:32
[ICEM] ICEM - just mesh specific parts hector88 ANSYS Meshing & Geometry 2 June 30, 2015 08:35
[snappyHexMesh] Parts of Geometry not meshed by snappyHexMesh Turbulence OpenFOAM Meshing & Mesh Conversion 5 August 8, 2012 16:27
Merge two meshed faces Ganeshsswamy ANSYS Meshing & Geometry 1 September 12, 2009 09:17
