[ICEM] Increasing mesh Quality for a simple geometry |
May 26, 2018, 04:54 |
ahmad
Rep Power: 8 |
hello seniors,
I am doing a heat transfer analysis on a surface that has walls at its edges at 60degree. previously I had performed the same at30 and 40 degrees and faces no such issues. When Iran fluent calculation it diverges after 50 iterations. (usually takes 200 iterations for convergence in other cases). After some research, I found that the mesh quality under the angel tab is low, especially in the region of high interest. Pics are attached herewith, would appreciate if someone can give provide some solution. I tried further splitting, moves the vertices and smoothing options but all these further deteriorate the situation. |
[snappyHexMesh] very bad quality snapped mesh | federicabi | OpenFOAM Meshing & Mesh Conversion | 18 | September 26, 2018 10:33 |
[ICEM] Unexplained changes of mesh quality and blocking approach | salumi | ANSYS Meshing & Geometry | 9 | November 23, 2016 04:14 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
