[ANSYS Meshing] spaceclaim CFD meshing zone interface setting
Old   January 26, 2017, 17:23
Default spaceclaim CFD meshing zone interface setting
Yizhou Yan
yzhyan is on a distinguished road
I am trying to create multiple cell zones so that I can have different porosity in each zone. This is a 3-D asymmetric model, and I generated the mesh using Spaceclaim and Meshing tools. Right now, I can get several zones, but how do I set the interface between the zones in Spaceclaim or Meshing. The zones should be in a continuous flow domain. Thank you in advance.
yzhyan is offline   Reply With Quote
Old   October 12, 2018, 06:00
Smile spaceclaim CFD meshing zone interface setting_share topology
Pratik
J_Pratik is on a distinguished road
@yzhyan, while modeling in the spaceclaim, you have to select all the required bodies for your analysis from tree structure. After that, create a new component with right mouse click. Go to properties of newly created component using right click. In Shared Topology option Select type from none to share. Using this, you can get conformal mesh between multiple volumes.
J_Pratik is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
[ICEM] ICEM CFD Interface meshing problem gamemakerh ANSYS Meshing & Geometry 1 December 12, 2016 03:41
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
