[ICEM] ICEMCFD ERROR: pIPartMgr->AttachAssembly() failed.
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   November 16, 2018, 00:28
Smile ICEMCFD ERROR: pIPartMgr->AttachAssembly() failed.
N/A
lgn_aero is on a distinguished road
Hello Friends,
I have UG NX 10 and Ansys 19.0 installed in my workstation. In attempt to import UG ".prt" file into ICEMCFD; ICEMCFD throws an error message as: ERROR: pIPartMgr->AttachAssembly() failed.
A parasolid exported from same UG .prt then imported into ICEM and this works fine.
I wish to import directly from UG NX 10 or higher versions only, please do help me on this issue ?
lgn_aero is offline   Reply With Quote
Old   November 16, 2018, 02:53
Gert-Jan
Gert-Jan will become famous soon enough
I had the same errors but with other file-formats. ANSYS showed me that these were fixed in 19.2. I recommend to use this.
lgn_aero likes this.
Gert-Jan is offline   Reply With Quote
Old   November 20, 2018, 05:46
N/A
Thank you so much, I will try 19.2 then.
Old   January 6, 2019, 14:14
N/A
I have tried with ANSYS 19.2 also problem not resolved......
Old   March 23, 2019, 07:11
N/A
Any update on this issue...!!!!
Old   March 6, 2020, 01:39
Aveek Pal
Aveek Pal is on a distinguished road
You have to select working points and lines in the option. It worked for me.
Aveek Pal is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
