[ICEM] ICEM struct mesh diverges, ANSYS unstruct does not
Old   February 27, 2019, 16:32
Default ICEM struct mesh diverges, ANSYS unstruct does not
Ramaswamy Devakottai
rsdevako is on a distinguished road
Hi all,
I am trying to simulate a jet impingement on a flat plate (single jet).
BC for the simulations:
  • Inlet - Mass flow
  • Jet walls - wall
  • Outlet - Pressure outlet
  • TargetPlate - Wall, with const. heat flux - 1000 w/(m^2)
Initially, I meshed the geometry with ansys meshing tool - from the workbench. This was an unstructured mesh. The simulation produced satisfactory results without divergence.
Then, I tried to simulate for the same geometry, using a structured mesh - using ICEM CFD. The BCs were same as that of the unstruct mesh.
Observations for the simulation using ICEM mesh:-
  • The file from icem is imported to fluent without any errors.
  • But, when running the simulations, right from the first step, there is an error message displaying: "Temperature has been limited to 5e+03K in zone .. and 1.00e+00K in zone.." - which corresponds to the exit and inlet respectively
  • When viewing the diverged contour, there was high temp contours near the jetwalls - I honestly cannot understand why this happened.
Thinking that I made an error in struct meshing, I tried simulations with new meshes - I improved the mesh quality to 0.7; still no result.
Then I tried the same case for a square duct - still the same error.
I humbly ask of you to help me figure out the problem -- I have been struck with this error for 2 weeks :'(
Thank you so much guys!
rsdevako is offline   Reply With Quote
Old   March 1, 2019, 00:44
Default Still not working for a geometry from icem cfd tutorial manual
So I created a structured mesh using icem for one of the geometries specified in the tutorial. I followed whatever steps they had mentioned, exactly.
I ran a simulation for this geometry, with similar bcs mentioned in the main post.
I am still getting the message: 'Temperature limited to 5e+03K on zones...'
Can someone please give me pointers on where I might be going wrong?
Thanks.
Old   March 4, 2019, 03:32
Gert-Jan
Gert-Jan will become famous soon enough
I think the problem is in fluent not in ICEM. So I would consult the Fluent forum. Probably it is something numerical.
As a start I would set the limits in fluent to realistic values. Depending on the problem you are solving: minimum 273 K and max 500 K?
Gert-Jan is offline   Reply With Quote
Old   March 6, 2019, 02:26
Okay. I will try posting this on the fluent forum.
Yes, I will try limiting the temperature values.
Thank you!
ICEM of ANSYS V15: how to export .msh mesh for CFX hydroaero ANSYS 1 March 9, 2015 22:17
[ANSYS Meshing] ANSYS mesh - I was surprised... assafwei ANSYS Meshing & Geometry 0 September 4, 2014 12:17
How to Export ICEM mesh to ANSYS Structural SIVAPRAKAASH CFX 4 December 27, 2007 23:54
help, ICEM mesh export to ANSYS Fred CFX 3 June 28, 2007 13:51
ANSYS ICEM CFD smoothing mesh corner chamfered Hans CFX 4 January 26, 2006 16:00
