[ANSYS Meshing] Cutcell incorrect meshing size
Old   March 27, 2019, 05:09
Default Cutcell incorrect meshing size
Daniel
dlkadk is on a distinguished road
I have rather simple box shape geometry, with height of 2.4m (image attached)
I want the cutcell meshing, with all the cube size as 0.1 x 0.1 x 0.1.
So, the box should have exactly 24 cubes in height with 0.1m high each.
However, when I run the meshing, it has 25 cubes with each cubic height slightly less than 0.1m. I tried with additional definitions such as edge lengths. BUt the result is the same.
Anybody has a clue?
dlkadk is offline   Reply With Quote
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 09:29
[ICEM] ICEM CFD meshing lock edge mesh size vickyiamlucky ANSYS Meshing & Geometry 1 April 28, 2017 08:27
[ICEM] Meshing Size Problem eRzBeNgEl ANSYS Meshing & Geometry 2 April 17, 2011 15:53
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
