[ANSYS Meshing] Cutcell incorrect meshing size |
March 27, 2019, 05:09 |
Daniel
Rep Power: 10 |
I have rather simple box shape geometry, with height of 2.4m (image attached) I want the cutcell meshing, with all the cube size as 0.1 x 0.1 x 0.1. So, the box should have exactly 24 cubes in height with 0.1m high each. However, when I run the meshing, it has 25 cubes with each cubic height slightly less than 0.1m. I tried with additional definitions such as edge lengths. BUt the result is the same. Anybody has a clue? |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[ICEM] ICEM CFD meshing lock edge mesh size | vickyiamlucky | ANSYS Meshing & Geometry | 1 | April 28, 2017 08:27 |
[ICEM] Meshing Size Problem | eRzBeNgEl | ANSYS Meshing & Geometry | 2 | April 17, 2011 15:53 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
