[ANSYS Meshing] Meshing Using Named Selections |
May 21, 2019, 05:05 |
Amgad Abdelkader
Hello Everyone;
I optimize a wind turbine blade using ANSYS Design of Experiment. Geometry is generated using Spaceclaim script. I need to make an inflation layer at the surface of the airfoil. To automate the process, The scope and boundary in the inflation method is determined by using named selection created by spaceclaim script. Every time I change a parameter, Ansys Meshing asks me to manually select the named selection each time. please, Can anyone help me with it? Last edited by Amgad Abdelkader; May 23, 2019 at 05:48. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
only 1 of many named selections not showing up in cfx pre | mihirbhagat | CFX | 2 | April 26, 2019 04:56 |
displaying named selections during analysis setup | assafwei | FLUENT | 0 | November 6, 2014 11:57 |
Adding Named Selections | Matty_A | FLUENT | 1 | June 12, 2014 06:18 |
named selections are not transferred | amir00251 | FLUENT | 0 | August 4, 2012 10:46 |
