[ANSYS Meshing] Interface between a fluid and air
Old   June 19, 2019, 12:13
Default Interface between a fluid and air
Yoann Di Maiolo
ydima is on a distinguished road
(I am a French student, sorry for the language mistakes)
I try to simulate a flow from a syringe into air. I have sketched a syringe, a ground, and a frozen rectangle cut (through a Boolean) between them for the air. However, I have a major problem: I don't know how to make understand to the software that I want the flow to sink into air at the end of the syringe (as a hole). I have tried a lot of things, but in the results I have either all the fluid staying in the syringe, or all the fluid staying in the air, like if there was a concrete separation between the two.
On left and right sides of the interface between syringe and air I have put walls for named selections, but I don't know what to put for the end of the syringe (by the way I have 2 segments superimposed here, one from the syringe part and one from the air part).
I have enclosed many pictures to clarify everything.
If someone could help me, I would be very grateful
Thank you!
ydima is offline   Reply With Quote
Old   August 13, 2019, 07:19
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Yoann,
If you just want to simulate the air flow leaving the syringe you should use the flow domain (cf. your 2nd picture) and use a name selection at the syringe inlet edge. Do the same for the other BC (wall / outlet / opening) with appropriate names so when importing into fluent it will already pre-assign the BC type.
Have fun
Gweher is offline   Reply With Quote
Old   August 13, 2019, 08:58
Yoann Di Maiolo
ydima2 is on a distinguished road
I've fixed the problem since this post but thank you very much for your help!
Yoann
ydima2 is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
