Ansys Fluent Mesh Inflation direction
Old   September 13, 2019, 03:40
Default Ansys Fluent Mesh Inflation direction
Bineet Mehra
bineet_aero is on a distinguished road
I am trying to simulate a very simple case of conjugate heat transfer. In the pic1 the geometry is shown which is a channel with three flow passages. When i insert inflation layers in ansys mesh, they get added to the solid part and not the air domain (pic2). In local inflation method, the geometry selected (scope) was the solid while in the "definition" solid faces were selected through which the air would pass. I want the layers in the flow channel. Please suggest. Thanks
bineet_aero is offline   Reply With Quote
Old   September 16, 2019, 12:17
Eduardo
Etnowar is on a distinguished road
I think you should change your scope geometry to fluid domain.
Regards
Etnowar is offline   Reply With Quote
Old   September 17, 2019, 03:15
Bineet Mehra
Regards
Hi, thanks a lot. Selecting fluid domain in the "scope" renders the solid wall unavailable for selection in the "definition" tab.
Cheers
ansys fluent meshing, inflation layers
How to define a hole as boundary condition in Ansys Fluent using Fluent an mesh only? Nagu Sattenapalli CFD-Wiki 0 August 12, 2019 04:03
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 21:41
Mesh deformation in ANSYS Fluent DDPM roopesh99 FLUENT 8 June 2, 2016 10:44
[ANSYS Meshing] ANSYS Fluent mesh export: nodes and edges Nereus ANSYS Meshing & Geometry 1 December 15, 2011 11:41
how to transfer a mesh from workbentch into fluent using ansys 12 0617157 ANSYS 2 March 21, 2010 14:07
