[ANSYS Meshing] Why can't set geometry in Named Selections? |
November 16, 2019, 20:05 |
Zhouyueyang Cheng
Rep Power: 6 |
I am a beginner in using ANSYS fluent.
In order to create different sizing of meshes, I created three components, and Body of influence was used to create the meshes. When I create the named selections, I met some problems. I created a pressure-outlet smoothly. But when I created the velocity-inlet, when I set the geometry, it always failed. When I click the edge of velocity-inlet and click apply, the edge would add into the geometry but in the geometry, it still said "no selection". I think it may because the pressure-outlet belongs to Component 3 but not belongs to Component 1 and 2, whereas the velocity-inlet belongs to Component 1, 2, and 3. But I do not know how to overcome this difficulty. Would you please explain it and teach me how to solve this problem? Thank you! |
November 18, 2019, 13:46 |
Zhouyueyang Cheng
Rep Power: 6 |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
only 1 of many named selections not showing up in cfx pre | mihirbhagat | CFX | 2 | April 26, 2019 04:56 |
Changes to named selections not appearing in CFX? | steady-state | ANSYS | 3 | January 29, 2017 12:29 |
[ANSYS Meshing] Missing Named Selections | kschong | ANSYS Meshing & Geometry | 3 | June 4, 2012 04:04 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
