January 23, 2020, 06:34 |
Sweep problem
Chris
Rep Power: 13 |
I am trying to create a swept mesh on the body in the picture below. I've set the number of divisions on the circumferential edges and (in a separate edge sizing) the radial edges. Every time I try to mesh, I get this error:
"The number of divisions specified in sweep method is inconsistent with the internal number of divisions in mapped face meshing. Please check the specified parameters" Can anyone tell me what this means and how to fix it? Thanks, Chris |
January 24, 2020, 03:36 |
Stuart
Rep Power: 25 |
Switch on the display vertices just to check that you do not have an unexpected vertex on an edge.
January 24, 2020, 07:37 |
Chris
Rep Power: 13 |
Thanks. I worked out a way of fixing it in the end - I'd thought it was sweeping in a different direction to the way it actually was, so I manually selected the start and finish faces
Problem diverges when exhaust valve opens | swerner0711 | AVL FIRE | 0 | September 21, 2018 07:14 |
[GAMBIT] Sweep Problem | acalado | ANSYS Meshing & Geometry | 2 | September 17, 2018 16:02 |
Convergence Problem in Multiphase problem (three phases) | m.uzair | FLUENT | 0 | August 2, 2018 08:23 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
