[ANSYS Meshing] Help with meshing a complex geometry |
April 7, 2020, 06:13 |
HS
Rep Power: 10 |
Hi all,
I need to mesh the attached geometry (please see below link to the STL file) as it forms part of a structural analysis I am carrying out. Any suggestions on how to do this as it is a complex geometry? I have cleaned it as much as I can using meshlab tools but when I try and mesh the geometry using ANSYS meshing it fails to do so. Thanks https://drive.google.com/file/d/1joH...ew?usp=sharing REMAIN_VOL.png |
April 7, 2020, 12:30 |
Gert-Jan
Rep Power: 27 |
You need to close it completely. Then I would mesh it in ICEM. This is very forgiven for sloppy CAD.
April 8, 2020, 02:45 |
Mehdi Baba Mehdi
Rep Power: 15 |
I recommend to use gmsh. It is license free software, and you can import stl in your mesh. It's basically for FEM, which unstructured grid widely used, but you can generate structured grid and use it in CFD as well. There is bunch of video on youtube help you to do what you want, as well as the user manual in its website.
I hope it would help you Due to the problem of the website, I could not reply you message. |
ansys, complex geometry, meshing 3d |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
[ANSYS Meshing] Meshing complex geometry | cfdhydraulic | ANSYS Meshing & Geometry | 15 | May 4, 2017 10:09 |
Offer - Meshing complex Geometry using ICEM CFD | Nicooo | CFD Freelancers | 3 | December 29, 2016 07:49 |
Meshing Help for turbulent flow of a complex 3d geometry!!! | aabir | ANSYS Meshing & Geometry | 6 | June 14, 2016 19:46 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
