[ICEM] Improving Overall Mesh Quality metric
Like Tree1Likes
  • 1 Post By bluebase
Old   December 9, 2020, 01:58
Default Improving Overall Mesh Quality metric
VSO
VSOlawoore is on a distinguished road
Hello, community..
I am currently working on a wind turbine structured mesh. When I checked the 3*3 Determinant, the minimum was 0.4
However, the Quality metric was really bad with the bad cells concentrated on just one side of the domain. (Picture attached)
Kindly give me your suggestions. How do I solve this issue? Thank you very much in advance for your help.
VSOlawoore is offline   Reply With Quote
Old   December 9, 2020, 21:06
Sebastian Engel
bluebase will become famous soon enough
Are you sure the determinant was above 0.4?
Since the qualtiy metric shows a minimum value of -1, i guess, that you have negative volume elements in your premesh.
There might be a few edges intersecting each other, or the automatic edge path resulted in "intersecting" blocks. Check which edge is the cause, for example with the scan planes feature.
It might also help to link edges, to force certain edges into a more desirable shape in the area where you have that issue.
Another stray error might be, that an edge has been splitted by accident and a control point is shifted into an other block. This seems not unlikely to me, since the inverted elements form some kind of plume.
aero_head likes this.
bluebase is offline   Reply With Quote
Old   February 6, 2021, 01:29
VSO
Thank you so much for your response. I have since solved this issue.
icem, mesh, quality metrics
[ANSYS Meshing] general tips on improving mesh quality? Guille1811 ANSYS Meshing & Geometry 0 November 8, 2017 13:28
[ICEM] Unexplained changes of mesh quality and blocking approach salumi ANSYS Meshing & Geometry 9 November 23, 2016 04:14
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ANSYS Meshing] improving mesh quality gshankarau ANSYS Meshing & Geometry 2 April 10, 2014 07:02
