[ANSYS Meshing] Coarse Mesh to Fine Mesh outpu(.dat) transfer |
July 2, 2020, 14:08 |
Rep Power: 5 |
Hello everyone
I performed a successful CFD analysis with fine mesh(in FLUENT). However, I have to transfer output(.dat etc) of that analysis to a different mesh (same geometry but coarser mesh). How can I perform this transfer by using ANSYS ? |
July 6, 2020, 01:43 |
Gwenael H.
Rep Power: 20 |
Well if you want to use the results to perform another analysis, say structural deformation from fluid loads you can use the data mapping inside of Workbench. Have fun |
July 6, 2020, 01:56 |
Rep Power: 5 |
Actually I want to map this fine mesh results to coarse mesh.It is not for another analysis.Just mapping
July 6, 2020, 02:59 |
Gwenael H.
Rep Power: 20 |
Ok well if it's just for "visualisation purpose" you could either use an external data in conjunction with a simple model setup and import the field of interest to plot it on the coarser mesh.
Or if you have access to Ansys Ensight post processing tool there is also a way to map it there. Alternatively it should also be possible using paraview. You just need to export your fluent data first to the proper format (*.encas file), same with the coarse mesh. Or you could eventually use the plot csv extension (ansys appstore), to plot it on geometries / meshes. Have fun |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
[ICEM] Transition layers from quad (or hexa) coarse mesh to quad (or hexa) fine mesh? | macfly | ANSYS Meshing & Geometry | 4 | February 10, 2014 06:09 |
[GAMBIT] How to mesh a cylinder with fine to coarse cells | Bharatt | ANSYS Meshing & Geometry | 3 | August 12, 2013 00:45 |
fine mesh ==> coarse mesh | Mahbub | Siemens | 3 | October 11, 2003 01:19 |
