[ANSYS Meshing] Structured Meshing for Multi Element Airfoil |
December 26, 2020, 15:05 |
Janet J
Rep Power: 6 |
I am trying to create a structured mesh for a multi element airfoil on ansys meshing. Despite trying for several split patterns on spaceclaim, I am still unable to generate a structured mesh on the entire c-grid domain. Some splits are structured while some remain un-structured. Could anyone help me how I can obtain structured mesh on this C-grid for multi element airfoil? ~ J |
December 28, 2020, 03:58 |
Lorenzo Galieti
Rep Power: 12 |
I would forget about that Hexa mesh ( i suppose that is what you mean by structured) is a pain for anything but the simplest geometry
Did anybody tell you to do that? Why is it so required? |
December 28, 2020, 18:21 |
#3 | |
Janet J
Rep Power: 6 |
Yes, that is exactly what I meant, Hexa Mesh it is. I have spent a total of 15 hours in 3 days trying to get a nice structured mesh (Hexa mesh/mapped mesh) on this c-grid and I am only not able to get it completely. Reached to a fine level of exhaustion now. I have to do Hexa, it is a requirement. Thank you for your response |
December 29, 2020, 07:42 |
Lorenzo Galieti
Rep Power: 12 |
Hey man,
As I said, hexa mesh with blocking, forget about it, this wont work anytime soon and all you will get is exhaustion as you mentioned. What you can try is hex dominant mesh as meshing method, what it will basically do is create a tetra mesh and then try to automatically convert all the tetras into hexa. If your domain is 2D, the conversion may take place in a feasible amount of time. The advantage is that you can forget about the blocking, which to me is the “forget about it” part. However meshing time will be substantially longer, if I remember well we can even speak about hours. |
December 29, 2020, 14:12 |
#5 | |
Rep Power: 9 |
https://www.youtube.com/watch?v=tYrbScUH9RE https://www.youtube.com/watch?v=EknKVAJGEJ8 https://www.youtube.com/watch?v=6wQPeBpvwCk then here for strategies regarding meshing 3-element airfoils: https://www.youtube.com/watch?v=rfMnnzdd3JU and finally here for 3D meshes: https://www.youtube.com/watch?v=NVyvEH-u0wQ I should also comment on Janet's persistence to generate hex meshes by saying that oftentimes, people are not free to choose a meshing strategy because their solver can only be fed a certain type of mesh. Our in-house solver only takes structured multi-block meshes, so there's that. |
December 29, 2020, 16:19 |
#6 | |
Janet J
Rep Power: 6 |
And thank you for the video on 3D meshes, guess that's my next target once I am done with the current 2D one. |
December 29, 2020, 16:29 |
Lorenzo Galieti
Rep Power: 12 |
Good to know then, enjoy burning your fingers with ICEM
Edit: I will stress my point again: make sure you need a structured mesh and not just an hexa mesh, because if you only need an hexa mesh, I repeat that blocking is a lot of finger burning and, to be honest, sometimes I did not even find it worth. Especially if you want to add small refinement zones (e.g. in the wake of every split), it is also a pain because then you need a lot of elements everywhere to keep a decent cell aspect ratio |
March 7, 2022, 17:15 |
jose daniel
Rep Power: 6 |
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
March 8, 2022, 04:28 |
#9 | |
Void_CFD-user
Rep Power: 4 |
March 8, 2023, 11:19 |
#10 | |
Dipankar Sarkar
airfoil, ansys, structured mesh |
[General] Problem with reading in multiple grouped Ensight .case files into paraview | scro1022 | ParaView | 0 | November 27, 2020 08:00 |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. | DarrenC | Main CFD Forum | 5 | July 19, 2010 22:33 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 19:24 |
