[ANSYS Meshing] Help with a stl file meshing
Old   January 24, 2021, 18:20
Default Help with a stl file meshing
Shashwat
Legolas_1204 is on a distinguished road
I am trying to run the nasal cavity simulation. For that, I have obtained an STL file from the CT Scan data of a patient. This is my first time using an STL file for simulations so I am having a problem meshing it. I have tried several methods so far. My first preference was to use ICEM CFD but I couldn't find it in ANSYS 2020 R1 suit. I guess they have incorporated it in ANSYS Meshing. I tried using ANSYS Meshing as well but it shows an error 'the mesh generation did not complete due to poor quality elements or incorrect input'. I tried every option for meshing but couldn't get it done.
Can anyone help me with it, please? If someone can help me with Hypermesh or Fluent Meshing, it would be great. I tried Fluent Meshing but I couldn't find an option to make new boundaries (Like 'Named selection' in ANSYS Mesh). Any help would be appreciated.
Thank you.
Legolas_1204 is offline   Reply With Quote
Old   March 7, 2023, 10:26
Thomas M
tmik is on a distinguished road
You're not alone, it seems like although ansys can import an .stl, it needs to be extremely coarse for it to actually work.
It seems to me like it can't create an element which is exactly the size of the face. I think you might have sucess if your mesh size is smaller than the minimum .stl facet size.
tmik is offline   Reply With Quote
Old   March 7, 2023, 11:31
Daniel
zacko is on a distinguished road
Do you use a student version? - >ICEM might not be available there.
Did you try to use spaceclaim to maybe modify the geometry or convert it into another format which transform the mesh elements into actual surfaces?
zacko is offline   Reply With Quote
Old   March 7, 2023, 11:49
Thomas M
Spaceclaim autosurface and repair tools aren't able to create a CAD body, sadly.
I haven't tried ICEM, but I'll give it a go.
I have an enterprise license.
Here's to a +1 vote for a software update on .stl meshing!
Old   March 7, 2023, 11:56
Daniel
I have no experience in ICEM for. Stl files but good luck on that
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
