[DesignModeler] problem with "blend" command to smooth trailing edge |
March 2, 2021, 04:07 |
Ettore
Rep Power: 5 |
i'm designing a centrifugal compressor and i'm new to ansys CFD. From the simulations I did I found high trails near the trailing edge. For this I would like to smooth it with the "blend" command. I state that the geometry is generated through bladegen. The problem is that when I click on "Exportpoints" it takes all the blades except the surfaces modified with "blend". How can I do, to insert these changes in "exportpoint"? thank you |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 13:53 |
[GAMBIT] GAMBIT edge problem | SJD | ANSYS Meshing & Geometry | 4 | February 26, 2014 15:56 |
Structured mesh of a 3d sharp trailing edge | Gilles | Main CFD Forum | 2 | May 23, 2008 13:23 |
The trailing edge velocity | maximus | Main CFD Forum | 0 | March 6, 2005 00:27 |
trailing edge problem | Kuo Wei-Jen | Main CFD Forum | 2 | April 14, 1999 10:09 |
