[ANSYS Meshing] Problems meshing thin region ...
Old   March 6, 2021, 10:38
Default Problems meshing thin region ...
fanta is on a distinguished road
i have problems meshing with Ansys Workbench for OpenFOAM.
I made a simple sketch:
Workbench crashes, when meshing. Problem: there are two very thin (thickness 0,02mm) areas. Unfortunately i am dealing with non-newtonian liquids, so i need 5-7 tets in the 0,02mm thick area. That makes very small tets and i am running out of memory. Any ideas? Regards, fanta
fanta is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 08:12
Part based meshing VS Region based meshing Bharatt STAR-CCM+ 6 February 21, 2018 07:43
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
