[ANSYS Meshing] Problems meshing thin region ... |
March 6, 2021, 10:38 |
Rep Power: 14 |
i have problems meshing with Ansys Workbench for OpenFOAM. I made a simple sketch: Workbench crashes, when meshing. Problem: there are two very thin (thickness 0,02mm) areas. Unfortunately i am dealing with non-newtonian liquids, so i need 5-7 tets in the 0,02mm thick area. That makes very small tets and i am running out of memory. Any ideas? Regards, fanta |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Error when solving p_rgh | bob94 | OpenFOAM | 0 | March 17, 2020 08:12 |
Part based meshing VS Region based meshing | Bharatt | STAR-CCM+ | 6 | February 21, 2018 07:43 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
