May 13, 2021, 19:05 |
Show ruler?
How to show the ruler in ansys meshing 2019 r2?
Thanks |
May 14, 2021, 05:02 |
Stuart
Rep Power: 25 |
Go to the Display tab in the ribbon. On the right end is the Display / Show drop down menu to activate the ruler, legend and triad.
July 21, 2021, 17:15 |
Unfortunately, that does not always work. Here is a screenshot of the Display tab and there is nothing that allows the ruler to be shown.
July 22, 2021, 00:20 |
Kira
Rep Power: 8 |
I know of three other options:
1. You can measure the distance between two vertices if you pick the vertex filter and click then control click a second vertex, the distance between them is shown on the bottom of the screen. 2. You can see the co-ordinates at the bottom of the screen when you've selected one of your solutions and probed two (or more) points. 3. You can use hit point coordinate |
July 22, 2021, 03:54 |
Stuart
Rep Power: 25 |
I was saying go to:
July 22, 2021, 07:30 |
Ah. As you can see in the screenshot I posted, there is nothing to the right of "Sync ViewPorts" in my version (19.2), whereas you have an additional box with a sub-box called "Show". I can't tell what is written on the bottom because you have shown it with the drop-down activated. It must be a version difference, I guess. If anyone knows how to do this in 19.2, please let me know! |
July 22, 2021, 07:58 |
Stuart
Rep Power: 25 |
This screen was from 2021 R1.
I have never seen 2019 R2 and I've been using ANSYS since version 10.0. I have R19.2 (which does not have the GUI ribbon layout for me) and it was only from 2020 R1 that the notation changed for the commercial version I have been using. |
July 22, 2021, 08:27 |
#8 | |
Ok, thanks for looking. Do you have any idea where else I could go to get an answer? I often want to include images of my meshes in reports and such and it is very annoying that I do not have a scale to include. Where would you go to look if this were you? |
July 22, 2021, 09:12 |
Stuart
Rep Power: 25 |
I checked the 2019 R2 Mechanical User Guide and it shows the Ruler option in the Show drop-down box. I do not know why are not seeing it. I suggest you contact ANSYS Tech Support or upgrade to a newer version
July 22, 2021, 11:34 |
#10 | |
Great, thank you! I searched the documentation and didn't find this. You say it is in the Mechanical User's Guide? Perhaps that is why I didn't see it - I was searching in the Fluent User's Guide since I was using Fluent Mesher, not Mechanical. Maybe they differ? Thanks again. |
July 26, 2021, 04:38 |
#11 |
Stuart
Rep Power: 25 |
Your picture shows that you are not using Fluent Meshing, which is native in the Fluent Launcher. You are using ANSYS Meshing (which uses the same GUI layout as Mechanical) to make a mesh for Fluent as the outline tree shows you used a Mesh Component System in Workbench.
Ruler cannot be displayed | Jiricbeng | FLUENT | 5 | January 10, 2019 10:16 |
CFD post cannot load results-Error appeared? | mariam.sara | ANSYS | 9 | September 17, 2018 15:23 |
[OpenFOAM] field average calculated doesn't show up in paraview | Divyaprakash | ParaView | 0 | October 24, 2015 04:24 |
New Surfaces don't show up in contour plotting menu | ExG | FLUENT | 3 | October 20, 2014 14:57 |
how to set the fluent to show the 3D results in the xz plane? | poiu | FLUENT | 8 | January 30, 2013 06:51 |
