[Workbench] Minimum grid size value from fluent
Old   October 11, 2021, 02:15
Red face Minimum grid size value from fluent
suna
suna is on a distinguished road
I have simulated 2D NACA 0018 airfoil with 1m chord length. Reynolds number is 14.26x 10^6. From check mesh option, I got the minimum face area as 4.444515e-04 and minimum volume as 1.794975e-06. Here, I have used spalart allmaras turbulence model. y+ value is taken as 30. Hence, wall spacing value is 0.0000599m.
I have two questions:
1. As I have only chord length value. then how fluent is giving face area and volume value?
2. How could I get the value of minimum grid size from Fluent?
It is urgent. Please help everyone.
suna is offline   Reply With Quote
Old   October 11, 2021, 05:30
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
If I am not mistaken, Fluent uses the reference length (default value 1m) to derive "3D" quantities like face area or cell volume in a 2D case.
The minimum linear cell size should pretty much be the first layer thickness of your prism layers. If it's not, something probably went wrong. A quick visual inspection of the mesh should be able to spot that.
Long time since I last used Fluent, so no idea if there is a convenient and non-arbitrary way to get a value for minimum linear cell size in the bulk mesh region
flotus1 is offline   Reply With Quote
Old   October 11, 2021, 06:10
suna
Long time since I last used Fluent, so no idea if there is a convenient and non-arbitrary way to get a value for minimum linear cell size in the bulk mesh region [/QUOTE]
In that case, can we say the minimum grid size is the wall spacing distance (delta y)? I think delta y is the distance of the first node from the wall.
Kindly see the attached image.
Old   October 11, 2021, 06:57
flotus1's Avatar
Alex
Well that's how things should be for an airfoil mesh. I can't tell if your mesh looks like that.
And I can't tell if this is what you really want when referring to "minimum grid size"
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 12:16
[ANSYS Meshing] Minimum grid size value from fluent suna ANSYS Meshing & Geometry 0 October 11, 2021 01:31
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
[ICEM] Minimum Orthogonal Quality when imported to FLUENT pchoopanya ANSYS Meshing & Geometry 2 November 6, 2020 23:29
