[Workbench] Minimum grid size value from fluent |
October 11, 2021, 02:15 |
suna
Rep Power: 4 |
I have simulated 2D NACA 0018 airfoil with 1m chord length. Reynolds number is 14.26x 10^6. From check mesh option, I got the minimum face area as 4.444515e-04 and minimum volume as 1.794975e-06. Here, I have used spalart allmaras turbulence model. y+ value is taken as 30. Hence, wall spacing value is 0.0000599m. I have two questions: 1. As I have only chord length value. then how fluent is giving face area and volume value? 2. How could I get the value of minimum grid size from Fluent? It is urgent. Please help everyone. |
October 11, 2021, 05:30 |
#2 | ||
Alex
Rep Power: 46 |
Long time since I last used Fluent, so no idea if there is a convenient and non-arbitrary way to get a value for minimum linear cell size in the bulk mesh region |
October 11, 2021, 06:10 |
suna
Rep Power: 4 |
The minimum linear cell size should pretty much be the first layer thickness of your prism layers. If it's not, something probably went wrong. A quick visual inspection of the mesh should be able to spot that.
Long time since I last used Fluent, so no idea if there is a convenient and non-arbitrary way to get a value for minimum linear cell size in the bulk mesh region [/QUOTE] In that case, can we say the minimum grid size is the wall spacing distance (delta y)? I think delta y is the distance of the first node from the wall. Kindly see the attached image. |
October 11, 2021, 06:57 |
Alex
Rep Power: 46 |
Well that's how things should be for an airfoil mesh. I can't tell if your mesh looks like that.
And I can't tell if this is what you really want when referring to "minimum grid size" |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 12:16 |
[ANSYS Meshing] Minimum grid size value from fluent | suna | ANSYS Meshing & Geometry | 0 | October 11, 2021 01:31 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
[ICEM] Minimum Orthogonal Quality when imported to FLUENT | pchoopanya | ANSYS Meshing & Geometry | 2 | November 6, 2020 23:29 |
