[ANSYS Meshing] Discontinuity in cells between multiple geometries (with contact) |
August 25, 2021, 20:34 |
Kasik
Rep Power: 7 |
I'm planning on doing a CFD simulation on Fluent of a 3d printer extruder.
In simpler terms, the 3D geometry (see image 2) is a "inner tube" (the filament) with smaller diameter, and 3 cylinder-like geometries in contact with that inner tube (image 3). But I cant make the mesh have cells in contact between two different geometries (see image 1). Is there a feature/tool to connect two surfaces? Even if I put, for example, a sizing of same number of division on two geometries in contact, one is in a different angle (see image 1). I'm an amateur on meshing, so thanks in advance!! |
September 12, 2021, 15:10 |
Rep Power: 17 |
If I understand your aim correctly, you must use a "shared topology" from DM/Spaceclaim. In DM you do this by grouping the parts. This might open up some new opportunities with regards to efficient meshing (see Swept mesh).
September 12, 2021, 15:53 |
Ali
Rep Power: 4 |
Have you tried Contact sizing tools in mesh?
[snappyHexMesh] Bad looking cells with CastelledMesh | juvima | OpenFOAM Meshing & Mesh Conversion | 2 | January 7, 2020 09:40 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
Solid-Solid Heat Transfer with Contact Discontinuity | Jonas Larsson | Main CFD Forum | 9 | September 10, 1999 15:46 |
