[DesignModeler] change/increase model size box
Like Tree1Likes
  • 1 Post By jrunsten
Old   May 23, 2013, 11:33
Question change/increase model size box
Pjotr
oewnce932c is on a distinguished road
Hi all)
Is it possible to change in Ansys DesignModeller the "model size box"?
According to manual:
Model Size Box The DesignModeler application's geometry engine has a one cubic kilometer size box limit, centered about the world origin. This means that all geometry must be reside within 500 meters of the world origin. Any geometry created that extends beyond this size box may generate an error. For micrometers, the size box limit is one cubic meter, or 500 millimeters in any direction from the world origin.
i want to make enclosure around a ship with length of 230m. It means i need to change it up to 1.400m. thanks for answering!
yachting_rus cup
world amateur racing tour
WWW.YRC.DK
oewnce932c is offline   Reply With Quote
Old   May 24, 2013, 01:52
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
It's done in the dialog box where you select the units during import.
p36288 likes this.
jrunsten is offline   Reply With Quote
Old   May 24, 2013, 05:52
Pjotr
thanks jrunsten!
as i understand it is only possible to do at the beginning. It is not possible to change for an existing project in DesignModeller or?
yachting_rus cup
WWW.YRC.DK
Old   May 24, 2013, 06:55
Josef Runsten
To my knowledge, no. You have to do it in the beginning
Old   July 10, 2018, 04:44
Default DesignModeler...Scaling
Yaser
Haider58 is on a distinguished road
How to scale model size in Design Modeler. For example, if I select meter scale my model turns to be one meter long.. If I select inch scale it turns to be 1 inch long.. How can I scale up my model to 6 inches..
Thanks
Haider58 is offline   Reply With Quote
Old   April 8, 2022, 01:37
Default large model support
ashkan
ashkan0065 is on a distinguished road
before begin drawing the geometry, you should go to tool - options and in the unit section, enable the large model support. be careful: you cant enable this option in the middle of the geometry drawing.
Hope this is useful
ashkan0065 is offline   Reply With Quote
[ICEM] Model size inconsistency between DesignModeler and Icem Kristin_N ANSYS Meshing & Geometry 0 April 12, 2012 08:55
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
size of first cell near wall for k-epselon model mukkarum FLUENT 3 May 11, 2004 04:10
