[ICEM] Trouble generating Chevron nozzle mesh
Like Tree1Likes
  • 1 Post By mluckyw
Old   June 13, 2022, 23:56
Default Trouble generating Chevron nozzle mesh
Hoang Long
nvhlong2911 is on a distinguished road
Hello everyone,
I'm new to ICEM CFD and I have to generate mesh for a 3D Chevron nozzle in order to compare with a Baseline one. The mesh for Baseline seems easier than Chevron which has a number of chevrons at the outlet.
Can anyone give me some method or tool to deal with this problem?
Thank you very much!
https://drive.google.com/file/d/1Cf-...ew?usp=sharing
https://drive.google.com/file/d/1K9R...ew?usp=sharing
nvhlong2911 is offline   Reply With Quote
Old   June 17, 2022, 01:58
Chrowale
mluckyw is on a distinguished road
I think you can actually use two symmetry plane to analyze just one of the six chevron section, that way the blocking would be fairly easy.
I don't know if there's a combustion mixing in the region and if it's valid or not if you apply this method.
nvhlong2911 likes this.
mluckyw is offline   Reply With Quote
Old   June 20, 2022, 05:02
Hoang Long
Thank you very much for your help, Chrowale,
It's been for a while and now I'm able to mesh the geometry by splitting it in to 1:6, anyway, I'd try to do the meshing with the entire nozzle and check out the difference between them
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 13:05
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
